Need Help! FANUC SERIES O-T not ready
Results 1 to 3 of 3
Thread: FANUC SERIES O-T not ready
    Feb 2016
    Morocco
    Default FANUC SERIES O-T not ready
    Hello
    I have a FANUC SERIES O-T with not ready problem and after seen the ladder I saw that F148.6 bit cause this problem but I don't know what's mean this bit ?
    Attached Thumbnails Attached Thumbnails FANUC SERIES O-T not ready-wp_20170608_14_21_59_pro-jpg
    Feb 2015
    Default Re: FANUC SERIES O-T not ready
    F148.6 "SA" is the servo ready bit from the control to the PMC. Your servo's are not ready. The machine could be in Emergency Stop, or an axis could be on a hard limit switch, or there could be a "Machine ready" switch of some sort that needs to be pressed for that bit to be triggered by the servos. Other issues could be the problem also.
    In short, your servos are not ready.
    Feb 2016
    Morocco
    Quote Originally Posted by STLMachinist View Post
    Thank you for your help
