Old 03-06-2007, 03:01 AM
Swarf Bin is on a distinguished road
Fanuc 15T Backup Information
Hi there, I wonder if anyone can help me. I am taking a backup of my CNC lathe and already have the parameters. Is there a way I can output the diagnosis pages. I remember a long time ago on another control and machine (Fanuc OT) there was a sequence of button presses to output the diagnostic pages along with the parameters. Is this the case with ths control or do I need to write them all down by hand? Thaks in advance.
Old 03-06-2007, 08:43 AM
Al_The_Man's Avatar
Why do you want to output the diagnostics? they change constantly or depend on machine function.
Old 03-06-2007, 02:44 PM
I'm sorry I've made a mistake. It's the PMC Parameters and Ladder I want to save. When I go to the PMC side there is no I/O softkey option to get to the Write/Read page. Is this protected by keep relay or something?
Old 03-06-2007, 03:18 PM
Al_The_Man's Avatar
It depends on what PMC card configuration you have, The PMC may not be volatile if it is written in EEprom.
Was the intention of saving for back up purposes?
Old 03-06-2007, 04:52 PM
Yes, that's the intention. Do I not need to do it?
Old 03-07-2007, 11:43 AM
Al_The_Man's Avatar
If you have a Yellow Cassette sticking out of one of the Base cards, then there is eeproms inside, the machine only uses these to load into memory at power-on time.
You could actually remove the cassette, after power up and run, but as soon as you power down you lose the PMC. If you do not have the yellow cassette then you could have battery backed up ROM, but doubtfull.
Mazak M32 system disk backup sivaraj Mazak, Mitsubishi, Mazatrol 6 12-04-2010 05:20 AM
Example CNC machine Setup Sheet + program backup lug_wrench Machine Problems, Solutions , Wireless DNC, serial port 4 10-14-2008 08:24 AM
backup program of T1 and M1 to PC vpkurt Mazak, Mitsubishi, Mazatrol 4 02-08-2007 01:15 AM
Saving Mach3 Settings as backup? WarrenW Mach Software (ArtSoft software) 3 03-23-2006 08:02 AM
Backup Script.. Rekd Mastercam 3 09-11-2003 09:34 AM
