Same with my case
Hi all, I have a Mori seiki SL150 with a MSC518 (I assume its a Fanuc 18i) and the battery retaining its home position was dead when I got it. All of the other batteries seemed ok, but I went ahead and replaced all 3 of the batteries, but now need to get my turret position back. Right now it is on tool #7, the little LED position indicator says its on 7, so I am not sure if it is really "lost" but the TRCL light is blinking and I found one little sentence in one of the books I have for it that says that means the turret isn't clamped correctly. I am wondering if I just need to un-clamp and re-clamp the turret and things would be ok... Either way, I need to get rid of my "APC 300 3 axis need ZRN" alarm. I managed to finally figure out the Parameter 1815 and reset my X and Z home positions, I can now jog the machine around and home the 2 axis' and things like that, but I am lost about how to reset my turret . Any help would be greatly appreciated.
Same with my case
Not sure how to add an attachment, but if you send me a message with your email address I can send you a procedure I have when I worked for a Mori distributor.
Send to najippsp@gmail.com
Sir,
Could you send to my email address..Really appreciate your effort.. najippsp@gmail.com
I have the same issue,can anyone send me the procedure please. email= bpreslar@safefleet.net
Could you email me a copy of the reset procedure. I am in the same situation. Mori Seiki SL-153. Machine is stuck with Tool #2 at current position and I cant get the turret to index with the handwheel back to tool #1.
Thanks,
Email: TD3569@gmail.com
