Maybe this servo alarm...............??
Fanuc Alarm SV015 PULSE CODER DISCONNECTED
Fanuc Alarm Description
Fanuc 10/11/12/15
The pulse coder is disconnected.
Fanuc 10/11/12 Alarm Codes - Helman CNC
Regards,
Heavy_Metal.
I have a Fanuc11M controller on a Miyano MSV-41 mill. The controller in the bottom right corner under TOOL/ALARM NO has an alarm 15 that I cant reset.. Can anyone tell me What this means? Under the soft key alarm message it doesn't say anything. Please let me know if you know what this means. Thanks in advance
Fanuc 10/11/12/15
Regards,
Heavy_Metal.
[QUOTE=Heavy_Metal;2044598]Hi,
Do you know where this is? I was moving the machine fine and walked away for an hour or so and when I came back this alarm was flashing. Not sure where to look for this.
Every axis (XYZ) has it's own pulse-coder mounted on top of the motor.
Sometimes there is a extra encoder for the toolchange position (M19).
Is there also an alarm in the electical cabinet on one of the drives, shown by a led-display..?
Regards,
Heavy_Metal.
there is no alarms on the master board LCD screen. Everything looks normal in the electrical cabinets as well
Would this be a Miyano alarm? I unhooked one of the pulse coders and it did throw the code 15 on the main screen and told me what it was. This other code is just in the clear bottom right of the whole control board that also tells the tool #. Any other ideas? I dont know who else to help me with this problem. Thanks again!
