fordav11, to my knowledge the param 8000 trick only works on the 15A.
just to add, if you only have a hard copy you can first punch the parameters as-is then edit the file with any text editor just changing the 9000-series numbers to what your machine needs. then save the file and read it back into the machine through the serial port.
note this works for ANY Fanuc control except the very latest 31i/32i etc
Yes, I'm aware the 8000 PWE parameter is specific to the 15-series.
I'm specifically referring to punching parameters, edit file adding options, and then read parameters back into machine.
sorry, do you have all the parameters of FANUC 15. may I ask hardcopy pdf document. I ask for help because I have lost my documents .. please share
sorry thank you for your help
Do u still have the secret code?
Hy,
could you please send me the backup from the parameters. I have a 15T model, but it wont work.
Tnx a lot.
dnlpesek@yahoo.com
Hi, i have a 15T, may i ask for the parameters to. I can`t find the parameters for COUNTER and KEEP RELAY.
Where do i have to input the parameters for Timer (Sub24)?
Tnx, best regards,
Daniel
hi, i have a 15T model, could you please send me the backup. i wont to compare the parameters and see what i am doing wrong.
Tnx a lot.
Daniel
Hi
I am using fanuc 15M and i cant key in optinoal parameter in ipl mode
Please send me the procedure to key in optional parameters if any one have it
Dear posedi,
Can you share with me all those parameters that you set up by hand on your fanuc 15M? I currently have the same problem related to ram parity error but I don´t have any back up.
My emal is : oagundis@radikalsmart.com
I will really appreciate your help.
Best regards
Hello, I’m having the same problem, We are stuck at the IPL, we lost power to controller when the batteries went dead. Not sure if we need password. Can any one help with this? Thank you.
You will need a a backup of the NC and PMC parameters as a minimum. Do you have these? You can send an email to me at cnc@tulipmemory.com
email me at cnc@tulipmemory.com
