I bought a yang svm 1000 cnc machine with fanuc 0md controller.
the parameter on this machine was lost, fortunately i had the original full parameter list for my cnc.
so To mack sure every thing is correct i first deleted every thing by pressing (cycle power + Reset +Delete) to clear every thing on the machineand this is the result as in picture 1
After clearing every thing i entered the 900 parameters manually, then i used the "cimco edit" to send all the parameters.
When transmission completed i restated the cnc and checked all the parameters one by one.
After checking i found that 6000 and 8000 parameters are missing so i re transmit all the parameters again and restarted the machine.
finally i compared all the parameters of the machine with the parameter fileall the parameters was entered correctly, i checked them more than 3 times and one by one.
but the machine didn't work and didn't show any error as in the following picture
my machine has 4 servo drivers for x,y,x and the 4th axes but i don't have the 4th axes, could this be the reason for the error
how could i solve this problem, or at lest know the error when the alarm screen is empty and no error is displayed I really need your help, please help me
I am a real newbie on this control, but you have a "Not Ready" message on the screen.I am just starting to use it on a yang smv 600. It could be something as simple as a door interlock sensor? Are the drives themselves showing any errors on the LED?
Thank you for the reply, actually i checked every thing and all the cables, limit switches,encoders, and drivers but i didn't find any thing wrong
I have another yang cnc machine that has the same model and same controller, what i want to know as a start is how can i fined what cause the not ready error
the drivers and the spindle also showing not ready without error.
the fanuc ladder is enabled on the cnc , can i know what cause the error from it
any idea or comment may help me
thanks for all
