i have a kryle KVC 7
while i was working the machine went in emergency stop due to the contact of the emergency switch broke down
i replaced that switch and now the machine won't start up anymore
i get a "not ready signal "
i already checked the whole emergency diagram out and no faults i can see
in the diagnostics i found now that i have "1" in the 722 line
Check your servos. Your 3rd axis servo has multiple alarms. Overload(overheat), Low Voltage, High Current. Most likely the servo PCB on that drive is damaged.
