Coil G120.4 needs to turn on before this timer times out. Check to see why this coming in not turning on.
I get this alarm after a few seconds after the spindle get a run command. The spindle is running just fine at the set speed. But it seems like the control doesnt get the end OK signal and give an alarm.
I found the alarm in the PLC & parameter list for the machine, but i dont quite understand what the line says. Could anyone explain whats going on here? And what the problem could be.
Thanks!
I have also found the zero speed relay and/or the up-to-speed relay, which this looks like, on the spindle drive has failed, if it has the relay confirmation output.
Hmm yes that is what i am thinking also. But where does a relay like that sit in the machine? Its a Denford Cyclone with Fanuc 0T-B from 1988.
