PARAM 003 #4 (0010000 ) 6M/6T = CLOCK DISPLAY and RUN HOUR DISPLAY for the 6M.
Is there no counter on the screen ...?
When not, do you have a stop/warning light on the machine that flashes after program end (M30).
There are tons of electronic counters with RESET that can be controlled by the signal of the warning light via extended relais.
You can create your own counter, it's maybe not original but it works.
Search for Electronic Counter.
if you can use macro's you could write in to the program
#100=#100+1
then you would look at #100 after the cycle
#100 could be reset by mdi #100=0 after the set up
There is no macro-variable screen. I pressed "macro" button nothing comes up.
In the manual, it says to press "SET" button twice, it'll show macro variables. But that isn't working either. I press "SET", it just shows up SETTING Variables.
I contacted FANUC. they said counter came only after their 0M. so I think 6M cannot count. I might have to physically mount a counter.
