Hold "P" key and "CANCEL" at the same time, power on the control, this should remove the alarm and allow you to move the axes away from OT switch.
Recently I purchase a Supermax 1 Rebel, Changing the parameters for use a DNC software accidentally turn off the machine before restore the PWE to 0. When I restart the machine I cant move any axis and it show a massage " axis interlock". I need help! Thanks Folks!!!
Cincyice58, Thanks a lot!!! The cnc is moving again!!!
great to here
I have a supermax mill just purchased it. It came without parameters, I could read only scrambled letters and numbers. I reentered all parameters from the data sheet found.
I have an alarm so far "operator message" 2000.
Any ideas...
En aquel momento se encontro que la presion de aire que matiene el carrusel de herraminetas arriba no era suficiente , el control fanuc detectaba que el carrusel de herramineta estaba fuera de posicion.
