Is this a parameter issue? When I run a program in auto mode, tools are using wear values properly after execuing a T command, but when in MDI, executing eg. T0404 ignores wear altogether.
Hi, yes it is a parameter issue. A good place to start would be to look in your parameter manual for parameter 5002. Various settings but do not alter anything unless you are sure what you doing.
