serial to ethernet adapter on Fanuc 0M
Results 1 to 6 of 6
Thread: serial to ethernet adapter on Fanuc 0M
    Member Karl_T's Avatar
    Mar 2004
    Dassel.MN
    Default serial to ethernet adapter on Fanuc 0M
    This machine followed me home from the auction:
    https://www.machinesused.com/auction...mnum=846989990
    It has a Fanuc 0M control. I need to connect this machine to a PC to do anything serious with it.
    I was researching this and came across a mention of using a serial device to ethernet converter. Apparently this will put your machine on the local network. This would be REALLY GREAT for me it I can make it work
    Here's a couple examples i googled.
    https://gridconnect.com/industrial-s...FZm3wAodqWIIew
    https://gridconnect.com/rs232-ethernet-converter.html
    I am REAL WEAK on making this **** work. Anybody done something like this?
    Karl
    Dec 2003
    Default Re: serial to ethernet adapter on Fanuc 0M
    Did you get all parameters and macro's? Including the 900's?
    If not the first thing you need to do is back them up once you have the communication working.
    Dec 2003
    One other thing the 0M RS232 needs is to see the hardware handshake pin levels, either the signals themselves or the pins jumpered out.
    It does not use them for HS but requires the signal present.
    It uses XON/XOFF for s/w handshaking.
    Mar 2004
    Dassel.MN
    First thing I did was take a pic of every single parameter page, then install new batteries.
    i take it you have not used an ethernet adaptor, tells me not to go there.
    Karl
    Dec 2009
    ROMANIA
    you can easily put the 0M on a wireless connection too using this:
    serial to ethernet adapter on Fanuc 0M-p_20160713_095944-jpg
    Sep 2007
    u.s.
    Does it DNC?
    Where is the WHOLE THREAD describing this topic?
    If there is none WHY NOT?
    Thanks,
    Steve
