Need Help! Fanuc Tape Cut Display Died
Results 1 to 4 of 4
Thread: Fanuc Tape Cut Display Died
    Apr 2012
    England
    Default Fanuc Tape Cut Display Died
    Hi, I have a Fanuc Tape cut with a 6mb control which has been running fine but it has suddenly stopped and the monitor is flickering with no readable display. I have restarted the machine but no luck although the motors power on but I cant jog it etc. I have checked the voltages on the main board which are fine but there are leds lit on the Graph/punch card A16b-1200-0310B which indicates error D6. I have looked through all my manuals and cant find any reference to this so I was hoping someone can point me in the right direction.
    Member agering's Avatar
    Oct 2014
    Russia
    Default Re: Fanuc Tape Cut Display Died
    These LED serves not issue the errors for monitor. They are intended for determination the status of interface (RS232, FACIT 4070) signals.
    Possible trouble is in 14" monitor. If you need schematic diagram for 14" color monitor and PCB A16B-1200-0310, please tell me your PM.
    Apr 2012
    England
    Hi Agering, Thanks for your reply. I have looked at the monitor and the power supply a20b 1000 047 is low on voltage (3.5v) so that could be the problem. I have sent you a PM with my email address for the schematic.
    Apr 2012
    England
    Hi Agering, Your private message inbox is full
