So you turn it as one
Drill it as one
Then on part off
should be g0 X3.0Z-16
g1x0f?
g0 x3.0
w-(16mm parting off blade )
g1 x0
Alternatively you can do them as individual components using programmable work-shift G10
Line is G10P0 Z- (workshift )
Hello I have a old Colchester cmc2000l with fanuc ota controller... I am facing problems regarding programe pattern ...please check attached jpeg for drtsils
Drill it as one
Then on part off
g1x0f?
g0 x3.0
g1 x0
Thanks mbservice for your reply I attached my program and turning seq video...for clear understanding... I simply need this programs repeat at least 4 time with part length increment....I am not a expert in this field but learning... please guide me on my attached program... my machine controller is not accepting G50.G52 or other work shift adress...
Regards
Asif
Does G10 work? If so make it as a sub program.
Main program should look something like this
01
M98 P0000 (0000=PROGRAM 0)
G10 P0 W-11 (W OR Z)
M98 P0000
G10 P0 W-11
M98 P0000
G10 P0 W-11
M98 P0000
M30
Depends on you options you could place everything in one program
O0000
M98P00004 (0000= Program) (4=repeat)
G10 P0 W33(Putting work shift back)
M30
N1000
(Program goes here)
G10 P0 W-11
M99
hello again
please fill in the blanks
i want to run this programme with 1st part X25.0 Z0.0
2nd part X25.0 Z-20.0
3rd part X25.0 Z-40.0
please guide me i have a fanuc otA with no support of G10 ,G50, G52,to G59..just G92 is Enable .. But i dont know how i use it for workshift
O0001
M98 P0300
M98 P0300
M98 P0300
M30
