Problem Softkeys missing in Manual guide i.............
Results 1 to 7 of 7
Thread: Softkeys missing in Manual guide i.............
    Oct 2010
    Default Softkeys missing in Manual guide i.............
    Hi all,
    at the shop, on a 5 axis mill with fanuc 31i, the operator ask me if I could help him with the Manual guide i,
    so trying to help him but my problem is that I can't see the START, CYCLE, END etc...softkeys !!
    See attached pic, I can't see what 's in the red rectangle.
    Any tip ??
    thanks a lot
    Attached Thumbnails Attached Thumbnails Softkeys missing in Manual guide i.............-barre-jpg
    May 2016
    United Kingdom
    Default Re: Softkeys missing in Manual guide i.............
    what you cant see them on the screen
    Oct 2010
    No I can't see these softkeys on the screen !!
    May 2016
    United Kingdom
    Hi, are you in edit mode and use the left/right softkeys to scroll through the different softkeys. there is parameter values to change these keys but they should be set by default.
    Oct 2010
    Yes in EDIT mode, did try left and right, and parameter 14700 #7MGI is 0, so Manual guide is enable....
    May 2016
    United Kingdom
    Could you post a snapshot of your screen display whilst in Manual Guide mode.
  7. #7
    Oct 2010
    Yes i can, but not at the moment, I'll do it as soon as I can
    Thanks for your time
