Results 1 to 3 of 3
Thread: i need to change the chucking direction !!!
    Dec 2006
    argentina
    Exclamation i need to change the chucking direction !!!
    We received a MORISEIKI SL-35 lathe, and i cannot find the way for change the chucking direction. I mean, i need to use jaws for holding the spare parts, but from i.d.
    So, i need to change it because the machine doesn´t run, of course. Can anybody help me, please as soon as possible? i couldn't find any command on the operators panel for it. The control is a FANUC 16 t
    Thanks for your assistance !!!!
    MILTON SUAREZ
    Jan 2007
    I have an old Mazak ST-15 with FANUC 6T and the chuck ID/OD switch is located (hidden) in the rear electronics panel. Not very handy. That's all I can tell you.
    You would think that with the evolution, Fanuc woud have made it easily accessible thru operator accessible parameter. I know Haas did. But then again, Haas is very user friendly. Can't say that for Fanuc.
    Registered jackson's Avatar
    Oct 2006
    look for the key, but on some moris you have to go into a setting its been along time since i ran one so im not sure were it is but look through the control you should find it
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
  1. How to change Tool change position(About MAZATROL T1 control)
    By liushuixingyun in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-07-2007, 03:58 PM
  2. spline chucking
    By reachraghu in forum Work Fixtures and Hold-Down Solutions
    Last Post: 04-09-2007, 04:14 PM
  3. A axis direction change?
    By nervis1 in forum Fadal
    Last Post: 10-27-2006, 11:49 AM
  4. HOW:Line Direction change for MANY lines
    By rherman in forum BobCad-Cam
    Last Post: 09-20-2006, 04:43 PM
  5. How cutting direction change
    By freesman in forum BobCad-Cam
    Last Post: 07-28-2006, 04:02 PM
