Need help with 10tf option parameter #9
Results 1 to 3 of 3
Thread: Need help with 10tf option parameter #9
    Jul 2004
    Default Need help with 10tf option parameter #9
    Trying to reload parameters on to a MTC 3 Turning Center. On my documentation for option parameter #09 the factory print out lists 28 and then it's crossed out and written in pencil as an E8. Unfortunately I don't know the difference between the two and I have not been able to find information on the option parameters for a 10 TF on Google. Can anybody shed some light on the difference between the two. And if that might have an effect on me getting too hard stops on both the X minus and X plus. Thanks
    Attached Thumbnails Attached Thumbnails Need help with 10tf option parameter #9-img_4052-jpg   Need help with 10tf option parameter #9-img_4053-jpg   Need help with 10tf option parameter #9-img_4054-jpg
    Dec 2009
    ROMANIA
    Default Re: Need help with 10tf option parameter #9
    it it easy to convert binary to hexadecimal
    let me show you
    Binary Hex
    0 0000 0
    1 0001 1
    2 0010 2
    3 0011 3
    4 0100 4
    5 0101 5
    6 0110 6
    7 0111 7
    8 1000 8
    9 1001 9
    10 1010 A
    11 1011 B
    12 1100 C
    13 1101 D
    14 1110 E
    15 1111 F
    so now you group them depending on hwta you have
    28 means 2-0010 and 8 means-1000 so your result for 28 will be 00101000
    same for E8 ,for E-1110 and 8-1000 ,the result for E8 is 11101000
    the diference between them is that bit 6 and 7 are diferent and are option parameters
    you can input it with E8 option as will be better for you.
    Jul 2004
    Quote Originally Posted by zavateandu View Post
    let me show you
    Binary Hex
    0 0000 0
    1 0001 1
    2 0010 2
    3 0011 3
    4 0100 4
    5 0101 5
    6 0110 6
    7 0111 7
    8 1000 8
    9 1001 9
    10 1010 A
    11 1011 B
    12 1100 C
    13 1101 D
    14 1110 E
    15 1111 F
    Thank you for your response. I was aware of the hexadecimal conversion but I didn't have any idea what the number seven and six bit difference would change. After some digging I did find the parameters and found that bit six turns on the RS 232C B and the seven bit turns on RS 232 C . The description to the option parameters were rather difficult to find. But for future reference for anybody else that might be searching for them they are on docslide. Again thanks
