I lost parameters and had to reload them manually from a hard copy documents. Unfortunately in my back up documents I couldn't find any keep relay settings or data table data. I assume this machine uses at least three keep relays because there are three called out in the ladder diagram.. Does anybody know if this machine makes use of the data tables and if it does their configuration. Thanks
As an addendum I have a list of parameters that are not on the in NC parameter print out. Would this be the data table? If they are how would they be input manually thanks
