I have an urgent problem, we have a 1987 CNC machine center it model is Dahlih MCV610 equipped with controller Fanuc 10M.
I tried to backup the machine programs but unfortunately we lost machine parameters.
I contacted MTB and they send me the parameters and options parameters.
I have input them all as below
1 Power up machine with:
"-" minus sign depressed and
"." decimal point depressed
2 Key "99" and "Input"
4 Key in "2" or whatever # axes in parameter 9000 @ "AXIS" prompt
5 Step through options by # and key new Hexidecimal codes and "input"
Option 1 = 9100, Option 2 =9101 etc.
just "input" if no change req'd
6 If "clear files" appears, hit "Y" - will erase programs etc.
7 When 1st menu appears, key "6" and "enter"
after that the machine become ready but i can't move any axis ...... also when i tried to change the mode selector, the CRT just show MDI and HND .... when i change the model selector to Rapid or Jog or ZRN or EDIT or MEM or TAP the CRT does not change the mode, it only show HND or MDI only.
no safety door switches installed and all electrical connection is good.
the machine was working fine till i cleared the memory by mistake.
Now you have to get the NC and PC parameters back in; once you have set up the serial port, you can load the NC parameters. Then enter the PC parameters manually.
Make sure there are NO alarms before you restore programs, offsets ets.
