Originally Posted by
thebestjessins
So today I was having trouble with a decorative facing radius that blended into another radius. From the center there is a large arc that sweeps to the collet until it's vertical, then into a smaller radius that curves back toward the carriage that ends in a sharp ring like radius. Sort of looks like a top with a ridge around the edge. I can use g41 with a 7 style cutter to cut the radius that moves back outward and then half of the ring radius but I can't use it to cut the larger taper because of the tool shape. I feel like I should be able to use a neutral tool to cut both of the larger sweeping radius cuts but it doesn't seem to cut correctly like that. It stays on the right but it cuts one of the curves wrong. Can you switch between g41 and g42 while cutting? Is there rules as to when like during vertical or horizontal cuts? I would prefer to do this in a few continuous cuts as possible and it seems like something I should be able to do without a huge amount of effort but it's not working for some reason. I don't have any issues with cuts that are all one direction but when they come back on themselves I can't get a system figured out that works reliably. And just fudging numbers around doesn't seem very practical or repeatable.
