Old 02-22-2007, 12:22 PM
Dave1's Avatar
Dave1 is on a distinguished road
Takisawa TC-1 Fanuc 0-TC
Hello all!
New to these forums, great info I've seen posted. I do have a question however. I have recently purchased a Takisawa TC-1 with a Fanuc 0-TC control. I am waiting patiently for an Operators manual from ebay and a programming manual from Fanuc America. What other manuals are suggested? Is there actually a parameter manual? One thing I did find out when programming a M68 (collet close) it waits for something, the command does not cancel. M69 however, works fine. Opens the collet and cancels itself. I've tried it in MDI, within a program to no avail. The parameter page looks greek to me, not what I'm used to plus I have no explaination on what numbers mean what. Also looks to be Binary?
Thanks in advance,
Dave
(Schneider Machine)
(A force of one)
Old 02-22-2007, 01:06 PM
Al_The_Man's Avatar
Some M codes require confirmation, could be a pressure switch depending on the method the collet is closed.
There is a Description manual
Connection manual
Programming manual
Operators Manual
Maintenance Manual
Parameter Manual.
Operation & Maintenance Manual.
Then there is the MTB Manual for the Machine control and M codes etc.
Old 02-22-2007, 02:40 PM
Dave1's Avatar
Thank you Al,
I can change the clamp via the key switch to internal or external. That in turn reverses the commands. M68 now opens the collet and cancels itself. M69 on the other hand will not cancel. So, what ever it's waiting for is unknown as the problem changes
What manuals in the list do you recommend, what will I get the most bang for the buck out of? Besides the operators manual and programming manual because they are already on the way.
Thanks again,
Dave
Schneider Machine
A force of one
Old 02-22-2007, 02:55 PM
Dave1's Avatar
Thumbs up
OK!!!!! Found the pressure switch. I Adjusted it lower and the m68 code will cancel, I feel kinda stupid. This is my first hydrolic machine, used to pneumatic ones. Soon I will learn the idiosyncrasy's of this dang thing, after all, it's what keeps it interesting.
Dave
Schneider Machine
A force of one
Old 02-22-2007, 03:08 PM
jackson's Avatar
jackson is on a distinguished road
Chuck pressure will also cause your clamp un clanp to move slower primairly your clamp, not much slower but you can tell,
individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
Old 02-22-2007, 03:13 PM
Al_The_Man's Avatar
Dave
Send me a PM with an email address, some exceed the server capacity though.
Old 02-22-2007, 04:01 PM
Dave1's Avatar
Done,
Thanks Al,
Dave
Schneider Machine
A force of one
Old 02-24-2007, 03:00 PM
Dave1's Avatar
The programming manual from Fanuc America showed up on friday, sheese, does a person need a PHD and a Doctorate degree to understand the dang thing
Today the manual from ebay showed up, sweet, wish I'd got that first
Now it's time to do some tool block making, some reading, some programming, and some testing, but from what I gather the machine setting and tool settings are not what I'm used to. Seems confusing. Oh, it's not a G54 machine, it's a G50?????
Dave
Schneider Machine
A force of one
Old 02-24-2007, 03:26 PM
Al_The_Man's Avatar
See if you have parameter 910 bit #1 set (xxxxxx1x)
This should be G54~59
Old 02-25-2007, 10:19 PM
Dave1's Avatar
Al, that parameter is set to 0, I did try and change it to 1 and got 2 alarms, 401 and 430? I set it back.
Dave
Schneider Machine
A force of one
  #11   Ban this user!
Old 11-11-2008, 11:40 PM
Nilesh Patel is on a distinguished road
Dear All,
I have takisawa tc-1 with fanuc o-tc controler.
my problem was few day ago the Dignotics parameters are lots.
so please can help me,
anybody have same machine. please sand me a this parameters.
thanks in advance
nilesh patel
  #12   Ban this user!
Old 11-14-2008, 08:57 AM
Dave1's Avatar
Nilesh,
You have a private message
Dave
Schneider Machine
A force of one
Takisawa Ex-510,910 TURNING MAD General Metal Working Machines 1 01-26-2010 11:49 AM
Takisawa fanuc 5t m code tim-tbl G-Code Programing 3 06-20-2006 08:41 AM
Fanuc 21-TB M-Code Takisawa afterone Fanuc 5 05-28-2006 06:04 AM
Takisawa TC-2 Lathe kayleesdad Mazak, Mitsubishi, Mazatrol 11 05-10-2005 02:37 PM
Takisawa MAC-V2E kayleesdad General Metal Working Machines 0 04-08-2005 08:06 AM
