It was abandoned for some years and the batteries died, so all the parameters were lost. We managed to make it work but the problem is that the ATC moves and stops at the wrong position. What I mean is that when I press the button to move for example one step clockwise it moves clockwise but it stops about half a spin wrong from the position that it should be in order to grab the tool. This happens every time.
So I believe that it has to do something with the parameters and the position sensoring of the ATC axis.
If someone has a similar machine would it be possible for him to send them to me? Otherwise would anyone know which parameter should I edit in order to fix this problem?
