Dear Sir
We have a gear cutting machine
We are able to JOG in either directions and even reference B axis without any errors
In case of Auto cycle, B rotates less that 0.5 degree, then we get error SV323 B disconnect alarm by Soft
We have replaced encoder still same fault, we are checking feedback cable, Motor winding resistance, Meggering etc
Please advice further
Regards
- Need Help!- GE Fanuc Series 150M
- Need Help!- 50 Pin- SCSI HDD drive of capacity 45MB GE Fanuc Series 150M
- Need Help!- GE Fanuc Series 150M - Harddisk
- Need Help!- GE FANUC SERIES 150M
Sorry
I forgot to add.... we do have external encoder, we checked it externally, looks quite neat and clean, also checked intermediate connectors from External encoder upto drive, found ok
Yesterday we observed that no error when B axis is moved upto 72.203 degrees in Auto but if as per summary (program), if B is required to move even 0.1 degree more than 72.203 deg, we get errors
Please advice
To confirm this error due to external encoder, we dont have parameters except making 1815.1 as 0, any advice.........
Regards
