There is a procedure, had to set a D bit then you could use the MPG. My old external hardrive no longer boots as im sure its on there.
Sent from my SM-T813 using Tapatalk
on one ZL203 equiped with mapps and Fanuc
I loose the absolute zero position on the parts catcher (controlled by pmm)
Does anyone know how to move the part catcher in manual mode to start the reference counter ( necessary to enable zero return in prm 11)
Thanks.
Thanks for reply, I know that , i'm sure there is a Data for that, but witch one ?
Did you get the D address for that part catcher?
