Old 03-06-2004, 11:58 PM
Gerry Newe is on a distinguished road
DNC Feeding your Fanuc Controller
If anyone cares, a real simple way to DNC Feed (drip feed) your Fanuc Controller is by using the Windows 3.0 or 3.1 Terminal to communicate with it. It's an extremely versatile communication package, which you can configure to match the parameters of your controller. Find an old 386 or 486 computer that's running on the Windows 3.1 or 3.0 O/S, and you're good to go. All you need to do is turn on the "TAPE" mode and press the "START CYCLE" button. You can also send your files / programs from your controller to your computer, download and save your parameters & diagnostics, etc..
Just my 2 cents worth, Gerry
Old 03-07-2004, 01:56 AM
HuFlungDung's Avatar
Moderator
B..b.b.but Hyperterminal is not
Old 03-07-2004, 11:13 AM
Al_The_Man's Avatar
Gerry, I have also found Terminal a very good DNC program, Hyperterminal has problems using it for this purpose and its not as flexible ,Terminal will also run under Win95/98, I haven't tried it out on XP but I would think it would run ok.
Al
Old 12-03-2004, 02:51 AM
triumph406 is on a distinguished road
Al,
in Hyper terminal, how would I send a program to a Fanuc 0M controller?
My Multi-DNC has died and I need to send programs an alternate way!
Thanks for any help
Old 12-03-2004, 10:46 AM
Al_The_Man's Avatar
I would forget Hyperterminal, either use the free-bee from Cadem http://www.cadem.com/ncnet/freednc.htm they also have the typical parameters for you 0M, or I could send you the Terminal program if you wish it is not very large. You would have to obtain the protocol parameters that your Fanuc is using, baud rate, stop bits etc.
Al
Old 07-06-2010, 10:15 PM
Chipmonkey is on a distinguished road
Fanuc 3M DNC upgrade
Fanuc 3M DNC upgrades can be had from fanuc3mdripfeed.com which is a website dedicated to upgrading these old controllers. For more modern controls DNC is standard stuff, but the 3M control needs its EPROM chipsets replaced to acquire DNC. It takes about 20 minutes!
Not only do you get DNC, but the upgrade also deals with the other failings of the old 3M control: minimal memory, only 2 1/2 axis interpolation and original control EPROMs that start to bomb out after about 20 years (causing data scrambling, machine crashes and mother board failures) making control chip replacement an absolute must!
If you have an old Fanuc 3M check them out (fanuc3mdripfeed.com) and if you're willing to email them a file with your parameters and diagnostics data you get the whole chipset at half price (US$370 at time of writing this post).
Good luck!
Fanuc 18i-M controller Wjman Machine Problems, Solutions , Wireless DNC, serial port 9 10-01-2010 01:02 PM
Fanuc 3M DNC operation max_c General Metal Working Machines 3 07-04-2010 08:11 PM
Parameters No. for file transfer on a Fanuc O-mate controller Niall Fanuc 8 06-03-2009 09:14 AM
GMF Fanuc L-100 Robot R-F controller whiteriver Fanuc 5 01-28-2005 11:16 AM
Anyone here ever used a Fanuc Position Mate controller? Tarak Fanuc 1 10-18-2003 09:34 PM
