We have a Fanuc 18iMb Control System with DATA SERVER CARD option and we need to execute the programs from HD-DIR.
We have set the below mentioned parameters.
1- MDI Mode
2- Press System Key.
3- Press ETHPRM key
4- Press EMBEDD key.
5- Set the I.P. Addresses, subnet mask and Port No. 21
6- Parameter 20=5
After applying the procedure, the programs are successfully transferred from LAPTOP (Filezilla FTP software) to Machine and same are also visible in HD-DIR.
But when we are going to execute the same via HD-Dir then the softkey of DNC-ST has disappeared.
It is in our observation that DNC-ST softkey was visible before the above parameters changing. We have also undo the parameter but still DNC-ST softkey is not visible.
Please give your expert opinion in this regard that how to enable/ visible DNC-ST softkey.
