Is it possible to establish a gearbox ratio by examining the axis parameters?
The axis is a rotary table that is programmed in degrees. (see example part programme below)
I would like to calculate the number of axis motor revolutions needed for a 360 deg table revolution (one table revolution)
The system is the Series 0MC
The motor is 10S 2000 A06B - 0315 - B041/7008
The on board motor encoder is A860 - 0326 - T102 - 2500P
Can you point me to the axis parameters that would have needed to be set on first commissioning.
I hope that makes sense!
