Old 02-12-2007, 11:09 AM
posedi is on a distinguished road
Ram Parity (base0)
Dear all!
Today I powered up customer's Fanuc 11M machine and I got message:
RAM PARITY (BASE0).
Reading previous posts, I conluded that memory is erased due to bad battery.
How can I get alive this machine again? Where this battery is located? Is this battery on the front panel? This battery was not replaced 19 yeaers (machine is from 1988).
On BASE0 I have 01P1E modul, then on BASE1 is 01P1D and on BASE2 is 01P23~25 module.
Please can somebody provide me instructions how to get alive this machine...
Thank you very much!
Regards!
Old 02-12-2007, 08:35 PM
Al_The_Man's Avatar
The battery is normally within a short distance of the main rack, it is sometimes in the door of the cabinet in a black box, IRC there is 4 'D' cells.
Replace them with the power on.
To reload the parameters, set the serial parameters by hand and load the usual way with the PC. The option parameters have to be loaded as well.
Old 06-10-2007, 11:18 AM
viorel26's Avatar
viorel26 is on a distinguished road
Fanuc O-TD
System alarm:910 RAM PARITY(LOW)
-Reading previous posts, I conluded that memory is erased due to bad battery
-Where this battery is located?
Please HELP
Old 06-10-2007, 11:28 AM
Al_The_Man's Avatar
Depends where the OEM mounted them, some are accessible from the outside of the enclsure door (bad idea).
Most are within a short distance of the MB in the main enclosure, Black Plastic box with two wires going in.
They can be loaded by hand or PC (if PC,serial paramters have to be loaded by hand) , the PDF I have is too large to post, if you send a PM with email add I can forward a copy.
E94 C-ram Parity Error (low):80000 Craig F Fanuc 5 05-13-2012 01:23 PM
Ram Parity Error rags Fanuc 14 12-19-2008 02:03 PM
Fanuc 15 M Ram Parity Error(system Lable Lost) SBAGHAEI Servo Motors and Drives 1 06-07-2007 04:40 PM
Basic Rom parity alarm wanchai101 Fanuc 0 08-20-2006 11:07 PM
Stop Bits, Parity gar Computers and Networking 4 06-04-2005 02:10 PM
