Spock,
If you use G8P1, you will use the standard look ahead of the machine. If you use G05.1Q1 you will use an look ahead that has 20 blocks and 8 ms time of processing each segment.
Daniel
Can anyone tell me the practical differences between using g5.1 q1 L_, and using g8 p1? Can I use both at the same time? If not, is there a time when one works better than the other?
Spock,
Daniel
Was that a mistake or a kind of option to see more than 20 lines ahead
Hmmm by the way excuse my english I usualy speak french![]()
