We have a couple Mori Seiki MH-40 horizontals. On the one we can do helical interpolation ie pipe threads and on the other we can't. So I believe we need to turn on one of the 9100 series parameters. Can someone tell me which one it is? Thanks! Oh...it's an 11M control/ |
| Sorry for the interuption guys Nice DNC Software Dan. I'm very impressed.
| Mr. Fritz, I have an Fanuc 11M also, and just today was made aware that this machine is incapable of helical arcs. Unfortunately parameter list does not show #9100, I believe it might be hidden. Would you please explain a method to make visible. Thanks, Dan #2 |
| TheePress: The parameters in the 9100 area should be visible on all Fanuc 10, 11, 12, and 15 controls. They are not hidden. Be sure to press the SYSTEM soft-key (not the SETTINGS soft-key). Under SYSTEM, you should be able to see all the parameters. Under SETTINGS, you will only be able to see certain selected parameters that don't need to be un-locked with the PWE bit. You should be able to see these parameters in binary, but you can not enter the option paramters like the other parameters. You must use the special procedure that has been described before on this forum. Just to recap, it goes like this: power off, press "-" and "." at the same time, turn the power on, enter "99" then INPUT at the ILD menu, enter the number of axes, then enter each parameter in the 9100 range in hexadecimal Good luck. Dan |
THank You...Mr. Fritz, Succesfully added helical option, following youre procedure. In the future, could i not download parameters as a text file to computer, then use editor to change values in binary format and reload to machine? What other goodies might be enabled under these option parameters? |
#12
Can u tell me the optional para for helical interpolation for 16 M control please. |
| Need Helical Interpolation example for Heidenhain TNC355 | soweebee | Bridgeport and Hardinge Mills | 4 | 03-14-2012 07:36 AM |
| Fanuc 11M Helical Interpolation | MrMagooo | Fanuc | 3 | 11-15-2006 09:58 AM |
| Fagor 8055 Mill Sample Code and Helical Interpolation | sailcam | G-Code Programing | 3 | 10-12-2006 06:37 AM |
| hHow to smooth a program thats got a loop? (helical interpolation) | Darc | G-Code Programing | 6 | 08-22-2006 08:47 AM |
| Helical Interpolation | dbcoop11 | Bridgeport and Hardinge Mills | 4 | 12-31-2004 10:15 AM |
