Need Help! 900 option parameters
Results 1 to 7 of 7
Thread: 900 option parameters
    Jul 2016
    Netherlands
    Default 900 option parameters
    We have a Hwacheon HI-ECO 21HS Lathe with a Fanuc 0t control from 1995.
    I had alarm 910 and had to initialize the memory with RESET and DELETE.
    I have recorded the parameters but I miss the option parameters 900 to 940.
    It seems that they are skipped with recording.
    Does someone have the same machine and can you tell me numbers of the 900 parameters please.
    I asked the importer but they can not help me with a proper list.
    They gave me one but it does not work for this machine.
    Apr 2011
    Default Re: 900 option parameters
    When making a backup you have to press and hold the EOB key when you save the CNC parameters or the 900's will not be saved. So once you do get your machine running back it up using the EOB key. Also, save the diagnostics too
    Jul 2016
    Netherlands
    Thanks. I heared that from Fanuc also but the machine is dead for 6 weeks now and nobody can help. I have a list from Hwacheon but it is the wrong one and does not work.
    I hope somebody has the same machine and is willing to provide the numbers.
    Dec 2012
    The Netherlands
    Check your private message.
    Heavy_Metal
    The Netherlands.
    Dec 2003
    Also these may help in the future.
    Attached Thumbnails Attached Thumbnails 900 option parameters-fanuc0-15-16-18-21bakup-pdf
    Attached Files Attached Files
    Feb 2016
    Turkey
    Hi ;
    I have the sane problem as in this forum.
    We have a Hwacheon Hi Eco 21HS machine and due to an electricty problem we lost parameters.
    We have the back up but missing parameters between 900-940.
    Is there any chance that you can help us ?
    Regards
  7. #7
    Mar 2017
    Poland
    Hello,
    I have the same problem.
    I have the 900-940 parameters from other similar machine but not working.
    Could somebody tell me why?
    kind regards
    Krystian
