Old 01-30-2007, 10:52 PM
OC_ OC_ is offline
OC_ is on a distinguished road
setting tool offsets? 0M
I'm doing my first multi tool program, and I am setting the tool offset for the second tool wrong. I thought you would just go to the offset menu and enter the offset under the unmber 002 (for tool number 2), but i guess thats not correct. How do you set tool offsets?
I set my workpiece zero with G92 code with my first tool...
Old 02-02-2007, 03:45 PM
greyghost34 is on a distinguished road
Set your X and Y zeros with G92. Z zero should remain at machine zero (tool change position).
Bring tool one down manually and touch off work piece. Z will have value of something like -12.3434. Enter this value in any offset you want (lets say offset #1). Same for tool #2 and enter in offset #2.
In your program:
G0G90G49G28Z0T1M6
X.5Y-.5
G43H1Z.5S5000M3
M8
(CUTTING CODE)
GOG90G49G28Z0T2M6
X-.5Y-.5
G43H2Z.5S3000M3
M8
(FINISH PROGRAM)
G43 calls tool length offset H1 or H2
G49 cancels tool length offset
Good luck
Ken
Old 02-04-2007, 03:42 PM
OC_ OC_ is offline
I got it to work but did it a little differently.
I zeroed x,y,z (with g92) on my work with the first tool so its offset was zero. The second tool was shorter by 2.1" so the z was -2.1"... I set that for the offset on my second tool. Everything worked out great. I guess when it goes for a tool change; it goes to Z's machine zero and not to the work piece zero.
Really, it seems im doing the same thing as you stated; but off a different zero reference point.
Old 02-04-2007, 06:52 PM
Yes, essentially we are doing it the same way just with different positions for our Z zeros. Yours at the work piece and mine at the top of the stroke. If your second tool is longer than the first and you do a G49G28Z0 to go to the tool change position you will crash the tool. What if you left out the G49? Maybe no crash but overtravel at the top of Z? I can't remember. I'll have to try it. What about G49G28Z6.? No crash, no overtravel but you have to come up with a safe clearance for each tool.
I'll stick with the conventional way. Much simpler and easier to understand for this old fart who's been doing it that way for 22 years.
Be carefull. Things can get expensive.
Ken
Using G-Code for setting offsets firedog G-Code Programing 8 05-04-2010 12:59 AM
Tool offsets Clemmie Haas Mills 21 12-21-2006 01:24 PM
Tool offsets plateroomred CamSoft Products 7 05-28-2005 02:43 PM
Tool Offsets Hack TurboCNC 2 05-23-2005 06:28 PM
Setting Work & Tool offsets Shizzlemah Fadal 7 04-16-2005 12:04 PM
