Old 01-25-2007, 05:27 AM
Gorrell is on a distinguished road
G76 Parameter setting
Good Day,
Any help is appreciated......I have a Kiwa Mill with a Fanuc 10m control.
The entire parameter settings had to be restored recently and everything works fine except the G76 Fine Boring Cycle. It will feed down, do the oriented spindle stop, and at that point it should retract in the X- direction via a Q command in the part program. This is set to work in this manner from paramater settings at 6200 and 6240. Parameter 6240 selects the direction. The retract at the bottom of the bore will only move in the X positive, and it used to move in the - because all of the part programs are programmed that way.
Again any help is appreciated!!
T.Gorrell
Old 01-28-2007, 05:53 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
http://www.fanucamerica.com/fa_home/home.asp
Or someone here like Al_The_Man knows. I'd try Fanuc first to see what they have to say about this.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 01-28-2007, 07:48 PM
Al_The_Man's Avatar
It should be settable by those two parameters, do you have #2 set right in 6200? (xxxxx?xx).
Old 01-29-2007, 12:39 PM
Hello,
Thanks for the reply.
I have parameter 6200 all bits to 0. From what I gathered from the Fanuc book, bit #2 must be set to zero so the tool retract can be specified by a "Q" in the part program. That is working, but what are the correct values for X Y and Z in parameter 6240? The book does not specify. Currently I have X set to -2, Y is set to 1 and Z is set to 1. I have tried to change the sign on the X and it will not retract at all. Is there a correct setting for 6240??
Thanks.
Trevor Gorrell
Old 01-29-2007, 02:21 PM
psychomill is on a distinguished road
I know on other version controls, the parameter for G76 "Q" has two bits to set for direction. The different combination of these bits will tell the machine to move X "- or +", or Y "- or +". But if you parameter book doesn't show the different settings.......hmmmm.... someone should know the 10 model.... Al ??
It's just a part..... cutter still goes round and round....
Parameter setting for M198 call on Fanuc 0T Puma parminder Fanuc 16 10-10-2010 07:02 PM
0TC parameter for more memory? jani Fanuc 32 01-16-2010 04:44 PM
Fanuc parameter 901 mistux Fanuc 14 12-04-2009 11:28 AM
Set parameter from program....? REVCAM_Bob Fanuc 25 01-26-2007 08:11 PM
How to setting fanuc serial spindle parameter? ning Fanuc 1 10-30-2005 02:38 PM
