Old 01-20-2007, 07:47 AM
padobranac's Avatar
padobranac is on a distinguished road
Fanuc OM "memory dump"
How to send all programs stored in the memory of the machine to pc, all at onece, togeder (not one by one because it takes too much od time).
Control is Fanuc OM, and i use Cimco Edit for comunication PC-machine
Sorry for bad english
Old 01-20-2007, 08:26 AM
Cruiser is on a distinguished road
Not recommended !
Don
IH v-3 early model owner
Old 01-20-2007, 08:39 AM
padobranac's Avatar
I dont get you, it is not recommended to do that, or it is not possible?
Why is this not recommended?
Old 01-20-2007, 08:45 AM
every once in a while a slip of the finger does exactly that on the machine i work on primarily. All of the files in machine including the resident files for tool changing and probing routines etc. get dumped into ONE humongous file of which must be sorted out or dumped as being useless. best bet is to dwn load each file seperately for your backups and have all files backed up so that if in event of catasrophy ! i tried to do the seperating of the files, it can be done but it is not fun, and speaking of time ! think about it in that it takes even longer to dump everything ! then sort out later. Do your housework regular, don't wait till it is up to the window sils !
Don
Old 01-20-2007, 08:49 AM
Al_The_Man's Avatar
You can dump all the programs by entering -9999
or a range of programs from/to, by entering the start and end numbers.
e.g. Oxxxx,Oxxxx
I have had no problems yet.
Old 01-20-2007, 08:52 AM
AL, I do believe he was refering to saving the files, not just getting rid of them, and saving them as he is implying would create one large contiguous conglomeration of uselessness ! I had someone try it and i had to fix it !
Don
Old 01-20-2007, 09:07 AM
Al_The_Man's Avatar
This does not erase them, some people like to make a hard copy of all the files as one file for archive purposes, but it is usually easy to extract for editing etc. by cut & paste.
Old 01-21-2007, 03:33 PM
thd thd is offline
thd is on a distinguished road
Don't forget you need to set parameter 10 bit 4 to be able to save the protected system programs.
Old 02-02-2007, 04:26 AM
scappini is on a distinguished road
dump em via -9999 and then email it and pay a smart 10 y/old nephew/niece $100 bucks. It will be a deposit on a PS2 game for em, and will take em about, well for 450 programs like I got my nephew.....about 14 hours to put it on a *.txt file and email it back to you.. hehe..... good value for money if you ask me!!
Old 02-02-2007, 03:23 PM
greyghost34 is on a distinguished road
O-9999 send will send all programs.
O-9999 delete will delete all programs not protected
  #11   Ban this user!
Old 02-02-2007, 03:30 PM
Fraeserman is on a distinguished road
e.g. Oxxxx,Oxxxx
O-9999 ist richtig!
Old 02-02-2007, 03:42 PM
Al_The_Man's Avatar
Originally Posted by Fraeserman View Post
O-9999 ist richtig!
Ouch, I get a kick in the nuts, for being correct (richtig).
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
"memory protect key"? N.T.C-Guy Fanuc 2 01-08-2007 12:20 PM
"A" Axis Substitution Macro Programming For Fanuc xleng G-Code Programing 5 12-08-2006 01:52 PM
Vertical system "jerks" and "bangs"?? REVCAM_Bob Servo Motors and Drives 5 06-12-2006 09:09 AM
