Results 1 to 6 of 6
Thread: Fanuc 6t Paremeter
    Jan 2007
    Fanuc 6t Paremeter
    I Have An Ikegai Ax 25 And Reloaded The Parameters All Seems To Work Correct, Except The Offsets Value Are Added To The Crt
    Position X And Z So If I Command X2.0 And Add U.450 In The Offset
    The Machine Now Reads X2.450 Does Anyone Know What Parameter
    Keeps This From Happening
    Registered jackson's Avatar
    Oct 2006
    what exactly are you doing,
    individual who perceives a solution and is willing to take command. Very often, that individual is crazy.
    Jan 2007
    Fanuc 6T
    Quote Originally Posted by jackson View Post
    When I am say setting up the machine a running block by block and look at
    the Display the off set amounts are added to the programmed value, so I
    command G00 X 2.0
    G1 Z-1.0 F.004
    If my offset is U1.5 W.500 my display reads X3.5 Z-.500 my other 6T Machine will not add these values to the displayed moves, and my display reads X2.0 Z-1.0 of course the offsets are still there in the move.
    Thats why I think a parameter is wrong.
    Sep 2005
    Check parameter 007, bit #6 (the seventh bit from the right). If it's a "1", that would exlain your problem. Set it to "0".
    Jan 2007
    Dan thanks for the help, I tried setting bit 7 to 1 and 0 the parameter setting
    that the Ikegai book says parmeter 0007 00000001
    I did 0007 01000001 and 00000000
    No change the control is a System 6T from 1980
    Oct 2006
    has it always done this i know the newer machines dont, ut actually it may be better if they did you would know what was in the offset all the time HA HA
  • Posting Permissions
