| Good day all 1) we have a kingston lathe cnc with a 20-T control. the X axis belt went the way of the dodo bird and was replaced. our tech went thru a series of checks to see why there was no repeatabiliy. we copied and existing prmg in the controller to do some tests and it gave this copied prgm a #. it came up O0000 .( not the number I picked) I can not for the life of me delete this prgm. tried ever way in the book. when i look at this prgm in the edit mode, the prgm # is as follows, O0000 N; . since this prgm number, i can not upload or download prgms to and from the controller. does anybody out there have an idea as to what the heck happened? 2) There is a card slot on the main board and i need / would like to back up the ladder and such as another tech told me another way to delete this prgm that may wipe out everything in the controller. does anybody out there know how save to a compact flash card the contents of the controller. Thanks in advance. go have a coffee after reading this, pretty long. Gerry |
| Try calling up the program go to edit go in and change O0000 N; to O0001(N); then type in O01 and hit delet if it wont change then try O0 delete let me know if that helps
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
| hi Jackson no dice. i can bring it up in O search when in auto mode but when i switch the controller to edit it goes back to the list of prgms. i tried your suggestions of renaming it, won't go. thanks for your efforts. ttyl Gerry |
| so you cant do anything change programs, edit program that is currently in there. Go back to the pc and look at the program you up loaded see if there are any extra characters or any missing ones, i had the same thing happen on my haas but never on one of my fanucs
| It sounds like you have the memory lock key switch on. Al.
| the O0000 prgm was the result of copying a current prgm and the tech's "sexy fingers" when doing the copying process. i figured out my other challenge, brackets where required. training a new guy and he removed a bracket without having me check it out first. 1 problem down, one more to go Gerry |
| on the haas it would still down load and up load you would just get an alarm they had to wipe the mem.
