Old 01-03-2007, 05:49 AM
RLMTS is on a distinguished road
Question DPRINT Command 18Mi
Can anyone advise me on how to correctly implement the Dprint command using an 18Mi
Regards Rich.
Old 01-03-2007, 06:10 AM
lgreeves is on a distinguished road
My machine has an "M" code to prepare CNC for communication then a "POPEN" to start communication flow. All information is contained in brackets "[" "]" then a "PCLOS" to stop communication. A "DPRINT" is on every line of code. Example DPRINT [ MOVE Xx Yx ZX]. Finally an "M" code to finish. The "M" code is M70 but I am sure tha was designated by the manufacturer.
Old 01-03-2007, 06:36 AM
DPRINT Command - Fanuc 18Mi
Hi 'Igreeves'
Thanks for your reply.
There is obviously more to this than I imagined.
I am a self-employed machine tool engineer, mainly service, and a customer has asked me if I can advise in some way. They had previously contacted Hitachi Seiki who could not advise them?
Do you know if there is a manual available somewhere, or some instuctions on the programming syntax?
Obviously, if an M-Code is used to prepare, then we must get back to the MTB and pressurise them for information!?
Can you type me an example of how it would appear in the prog?
Regards Rich.
Old 01-06-2007, 03:30 AM
dcoupar's Avatar
Your machine must have the User Macro option turned on to use DPRINT. I don't believe there's any special M code required.
The following example is from the Fanuc 18iM Operator's Manual (Mill):
#2=128.47398
#5=-91.2
#30=123.456
POPEN
DPRNT[X#2[53]Y#5[53]T#30[20]]
PCLOS
Note: [53], [53], [20] are paired: the 1st # is the number of significant digits in the integer part, and the 2nd # is the number of significant digits in the decimal part.
If prm 6001 bit 1 (PRT) = 1, the above DPRNT command should output the following to the active RS232 port:
X128.474Y-91.200T23;
The POPEN can be commanded anywhere prior to the DPRNT and the PCLOS can be commanded anywhere after. Just be sure they're matching pairs.
Hope this helps.
Dave
Old 01-11-2007, 02:56 PM
18Mi DPRINT
Thanks "Igreeves" and thanks "Dcoupar" You have both been very helpful.
ATB Richard
Old 12-21-2009, 04:29 AM
harinct is on a distinguished road
could some one suggest how to use drpnt command for following need
1. job count (i hope we can store the part count in macro b variable) and send to pc
2. unused M code to run specific sub programs (where we can store the dprnt command like machine breakdown reason). so that we can use in MDI mode to run this M code to get detail on computer.
3. DETAIL on macro b variable storage and retrieve thro DPRNT.
Old 12-22-2009, 06:03 PM
MysticMonkey's Avatar
MysticMonkey is on a distinguished road
I think this will work
1.
O0001;(PARTS COUNT OUTPUT)
POPEN
DPRNT[PROGRAM-#4115[50]]
DPRNT[DATE-#3011[80]]
DPRNT[TIME-#3012[60]]
DPRNT[PARTSCOUNT-#3901[90]OF#3902[90]]
PCLOS
M2
2
Parameter 6070 = 69
M69 runs program O9009
O9009
{Output of alarms is not possible}
{ADD DPRNT data here}
M02
3.
Because of the limitations of the DPRNT command this has to be written longhand
O0001;(VARIABLE OUTPUT)
;(FOR VARIABLES 1 TO 149)
POPEN
DPRNT[VARIABLES-1-TO-149]
DPRNT[VARIABLE1-#1[99]]
DPRNT[VARIABLE2-#2[99]]
DPRNT[VARIABLE3-#3[99]]
DPRNT[VARIABLE149-#149[99]]
PCLOS
;(OUTPUT G53 SETTINGS)
POPEN
DPRNT[G53]
DPRNT[X#5201[94]]
DPRNT[Y#5202[94]]
DPRNT[Z#5203[94]]
PCLOS
;(OUTPUT G54 SETTINGS)
POPEN
DPRNT[G54]
DPRNT[X#5221[94]]
DPRNT[Y#5222[94]]
DPRNT[Z#5223[94]]
PCLOS
M02
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*_______Please give to charity http://www.oxfam.org/en/getinvolved_______*
Old 11-09-2011, 11:34 AM
metlshpr's Avatar
metlshpr is on a distinguished road
I know that I am digging this thread up, but i am at a place where I would like the common variable to be printed out from the control.
Here is what is going on:
I'm using a probe to do a first article on a part, then having the operator write down the numbers created on our inspection sheets.
Here is what I want to happen:
Probe to do first article and error out if part is out of tolerance.(I will write the macros as needed).
Then the control to print out the dimensions so the operator will attach that information to the inspection sheet.
So... How can that happen using the dprnt command?
WANNA GO FASTER
Old 11-09-2011, 01:35 PM
beege's Avatar
beege is on a distinguished road
I don't know how your customer(s) feel about this, but I believe that if you want to use your machine as a verification (measuring) tool, then you have to have it calibrated just like all of your off-line measuring tools, at regular intervals before you start using its results in your verification documentation.
Old 11-09-2011, 03:15 PM
metlshpr's Avatar
Wink
Probe is ran thru a calibration routine before each run.
WANNA GO FASTER
