Check X8.4 and G8.4. Both signals must be on to clear ESTOP
Hi
I have a yh-28 lathe with oi tc
it gives a emg alarm and it doenst go away and the emergency switch works normaly
I hope someone can help me
- Weird Rs232 issue/Mystery with Fanuc 6M on Mori Seiki . Calling all Fanuc Masters !
- Need Help!- Postprocessor for SolidCAM (FANUC OI-MD + FANUC Robodrill 31i model A)
- Need Help!- Fanuc drill tap center equipped with Fanuc OM-C i/o card details
- pro engineer post processor fanuc 18i mb5 and fanuc 180i Ma
- can fanuc ac digital servo amplifiers be run by a controller other than fanuc?
Can you see what in the ladder is preventing G8.4 from coming on? You need to search for the coil in the ladder.
do you have a pdf document with your electrical diagram?
or open the electrical diagram and in 1 page should be the entire emergency circuit,make a photo and post it.
you should check with a voltmeter if you have +24v DC in the emergency stop buttons and on the limit switch for hard travel for all axes.One of these has an interrupt.
show us a picture.If the limit switch is not pressed ,you should have 24v on it.
This is a standard Emergency circuit
you have the EMG push button than you have the overtravels 131,132 ,this is from a lathe so 2 axes limit switches,the +24v(L
+) goes in the EMG than goes to the switches and than in a relay and finally to L-.
So is like the christmas tree leds that are connected in serial mode.
all the contacts are normally closed so when 1 of these is open the 24V will not reach the relay so the machine will show alarm and NOT READY state.
the point is you must measure the 24V(L+) checking with the L-.
This is basic electric so i hope you understand it.
good luck.
I am having the same problem, but my F45 will not come on
Hi
i need help regarding 21i mb controller.On i/o card a20b-2002-0521/06A connectors CE56,CE57 i dont know on which pin number having *esp signal.
a1=24v,b1=0v i know that but other pins number which function it have i dont know can anyone help with this problem.
quick-cnc
The problem is these connections are variables. That mean it all depends on how the I/O assignments has been laid out. Fanuc states in this example:
Xm+0.0 M= starting address for this address. So if your starting address is X8 this pin would be X8+0.0 or X8.0
Hope that helps.
yes i think you are right but i dont know w to I/O assignment to do from X8.+0.could you please help me. rd181993@gmail.com.
thanks.
quick-cnc
Hi!!!
I have a similar problem with a Nakamura Tome TMC-12 Control Series 21-T, this machine was working well, until a technician came to check a vibration in the Z axis servo, apparently it loaded parameters and the machine did not return to work, I have a backup of the machine parameters, I reloaded them, no alarm comes out, but it is in EMG state, I can navigate the menus, but nothing else works (spindle, hydraulic system, turret , move the axes).
Hopefully someone can help me, best regards.
