First I want to thank everyone who helped me get this far but apparently I am missing something. I am trying to engrave on the O.D. of a piece of 2." round stock on my Lathe. Have a look at the macro prg. below and that part prg. and tell me if you guys see whats wrong. It gives me a "009 ILLEGAL ADDRESS INPUT" ALARM. I am trying to take the Y values in my prg and convert them to C-Axis moves in degress with the macro. Macro prg below.... % O9100(2.00 DIA MACRO CALL) G01C[#25*.0174] M99 % Part prg below..... % O1569(OVAL) N2#501=2.00 N3#502=[501+.1] N4G10L2P01X0.Z-23.4684 N5G10L2P02X0.Z-3.0123 N6G10L2P03X0.Z-20.4684 N7G10L2P04X0.Z-12.1784 N8G10L2P05X0.Z-5.3333 N9G11 N10/2M98P9998 N12M118 N13G28U0 N14G28B0 N16G99 N17G54M54 N18 N19(CHAMFER) N20G50G99 N21S3000 N22T1010G54 N23G0G96S1000M3 N24Z0M8 N25X2.1 N26G1X-.07F.006 N27G0W.05X1.7069 N28G42G1Z0.F.006 N29G3X1.7634Z-.0117R.04 N30G1X1.9766Z-.1183 N31G3X2.0Z-.1466R.04 N32G1G40X2.1 N33G28U0M9 N34G97 M05 M01 T1213 G98 G54 G0X0.Z.1 M69 G04P0500 G01Z4.0F500. M68 G4P0500 G0W.1 G28U0. G98 N39T0505(BALL END MILL) N40M43 N41G56G0C0. N42G97S4000M13 N43G0Z0. G0X2.1 G01X2.F20. G66P9100Z.0002Y.0117 This is where it alarms out.... N56Z.0007Y.0233 N57Z.0017Y.0349 N58Z.003Y.0466 N59Z.0046Y.0582 N60Z.0067Y.0698 N61Z.0091Y.0814 N62Z.0118Y.0929 N63Z.015Y.1044 N64Z.0185Y.1159 N65Z.0223Y.1274 N66Z.0266Y.1388 N67Z.0312Y.1502 N68Z.0361Y.1615 N69Z.0414Y.1728 N70Z.0471Y.184 N71Z.0531Y.1952 N72Z.0595Y.2063 The prg goes on for another 1600 lines.... thanks Jon Thee |
| I don't think you can use the letters that use as machine command address like G O Z Y X H few others.
__________________ The best way to learn is trial error. |
| My lathe only has Z, X and C with a sub spindle B. I am wanting to take the Y axis moves in the prg and feed C axis in degress in its place. thanks Jon |
| The Y address may not be permitted on a lathe. For the purpose of calling a macro, you can use any other address that permits decimal points, like "A". Also, CBNDude is right. If you want the Z axis to move also, you've got to make it move in the macro. The G66 macro call will just pass the numbers to the macro, and it won't move the axes at all. Try this to call the macro: G66P9100Z.0002A.0117 Then, inside macro 9100, move both the Z and the C axes with a single G01 command, like so: G01C[#1*.0174]Z#26 There should be a chart in the front of your operator's manual that will tell you the legal addresses, and it will also tell you which addresses can use decimal point formatted numbers and which ones are simple integers. For example, an address X, Y, Z, U, V, U, or A, B, or C should accept decimals. The addresses M, T, S, etc. are integers. Your lathe may not permit the addresses Y, B, or V because this axis doesn't exist on your machine. Just a guess ... |
