Ok I have the above mentioned laser and when powered up all seems to be fine no errors at all to home machine just push cycle start (runs program # 7900 and supposed to home Cycle start does nothing no errors no saftey device alarms nothing! just no homing. anyone have any ideas? |
| Having worked on Fanuc's for 20 years or so, if I were the tech's from Amada I would be ashamed of myself. That problem should have taken no more than 1 hour to come to a conclusion. I have written a lot of ladders for 0 series control and only a few things can stop the machine from moving when the subroutine for homing is called up. I am not familiar with Amada however I can tell you there is nothing I can't diagnose on that control within an hour. I see this all the time from factory tech's from (mtb) and some of them are lucky to find a customers plant without GPS let alone fix something without a dozen phone calls to the office. OK so maybe I exagerated it may take me 2 hours. Good Luck........if you can display the ladder and can give more details I can probably steer you in the right direction. Good Luck if you are around the Los Angeles area call me 714-334-4261 |
| Display your ladder and search for G120.2 this is the cycle start signal all the variables on that rung must be high to get a proper cycle start. You will see what is holding you off. You should see it turn off and on with the button Good Luck |
| I know I can't help you with your problem sorry, but by chance you may be able to help me if your wattage is the same. The company that I am programming their laser is having trouble cutting 3/16 and 1/4 steel and I think it is more of a machine than program problem. If your laser is a 1500 or 2000 watt could you share the G65 P9100 like the example below with the setting you use for 3/16 and ¼ material. Thanks G65 P9100 S1500 H90 B100 C20 I63 J0.1 W1000 Q90 T100 U0 I63 J0.0 Independent CNC Programmer www.ctcn,net/~3kings/ |
| G65 P9100 S1500 H90 B100 C20 I63 J0.1 W1000 Q90 T100 U0 I63 J0.0 I do not use an H or a Q ? AT APR. 50 IPM (might get away with up to 65 or 70) CUT SPEED & 1.0 kgf/cm2 This is what I would try. G65 P9100 S1500 B80 C25 I63 J2.0 W1500 T1000 U35 I63 J.5 Biggest thing i see is your U of 0 is giving you no duty cycle? And only using 1000 Watts for cutting? MUST have the 2.0 in the first J this is the time for piercing Hope this helps. please let me know? |
