Old 11-21-2006, 12:13 PM
Lex_1972 is on a distinguished road
G10.6 Tool Withdrawal and return
To replace the tool damaged during machining or to check the status of the machining , the tool can be withdrawn from a workpiece. The tool can the advanced again to restart machining efficiently.
The tool withdrawal and return operation consists of the following four steps:
* Retract
The tool is retracted to a predefined position using the TOOL WITHDRAW
switch.
* Withdrawal
The tool is moved to the tool change position manually.
* Return
The tool returns to the retract position.
* Repositioning
The tool returns to the interrupted position.
My question is this a option or is this a normal function on a Fanuc 18T ?
Can someone explane please how this works if it is not a option , like the
g-code comand.
If it is a option mayby someone have the right paramater for it
Regards Lex
