Results 1 to 5 of 5
Thread: two questions with fanuc
    Jul 2006
    China
    Question two questions with fanuc
    hello,
    First,i want to ask,how can i open copy&move function on Fanuc 0M control? which parameter? Second, the 9900s parameter on Fanuc i series is locked by fanuc inc., how can i modify it?
    Thanks!
    Ray
    Dec 2003
    Select MDI, set PWE bit to 1 allows entering parameters.
    Jul 2006
    China
    Angry
    Quote Originally Posted by Al_The_Man View Post
    So i did, but it could not. when i modifyed 9900s parameter, it displayed "write protect". I think where needs a password to unlock it.
    Aug 2006
    fanuc password stuff
    The password function locks PRG9 (bit 4 of parameter No.0010), used
    to protect program Nos. 9000 to 9999, by using the PASSWD (No.0797)
    and KEYWD (No.0798) parameters. When PRG9 is locked, PRG9
    cannot be set to 0. Therefore, the protection for programs numbered 9000
    to 9999 cannot be released unless the correct keyword is entered.
    PRG9 is locked when different values are set in the PASSWD and
    KEYWD parameters. The values set in the two parameters are not
    displayed. NE9 is unlocked when the value preset in the PASSWD
    parameter is set in the KEYWD parameter.
    0010
    #6 #5 #4
    PRG9
    #3 #2 #1 #0
    [Data type] Bit
    PRG9 Editing of subprograms with program numbers 9000 to 9999
    0 : Not inhibited
    1 : Inhibited
    The following edit operations are disabled:
    (1) Program deletion (Even when deletion of all programs is specified,
    programs with program numbers 9000 to 9999 are not deleted.)
    (2) Program output (Even when outputting all programs is specified,
    programs with program numbers 9000 to 9999 are not output.)
    (3) Program number search
    (4) Program editing after registration
    (5) Program registration
    (6) Program collation
    (7) Displaying programs
    0797 Password(PASSWD)
    [Data type] Two–word
    Set a secret number to this parameter. Its value is not displayed.
    CAUTION
    Once a key is lock, parameter PRG9 cannot become 0 and
    PASSWD cannot be changed unless you perform an unlock
    operation or perform the memory all clear operation.
    Special care should be exercised when setting the
    PASSWD parameter.
    Hope this helps, I'm not to good at copy/paste from PDF
    diemaker
    Jul 2006
    China
    Quote Originally Posted by diemaker View Post
    0010
    #6 #5 #4
    PRG9
    #3 #2 #1 #0
    [Data type] Bit
    0 : Not inhibited
    1 : Inhibited
    CAUTION
    PASSWD parameter.
    diemaker
    Thanks!
  • Posting Permissions
