10-24-2006, 02:03 PM
Once you type in your program in EDIT mode, you must switch to MEMORY mode, then turn ON your memory protect key switch, then you should be able to cycle start the program.
Some machines have interlock conditions on the Cycle start function, so you might have some machine condition preventing you from cycle starting. For example, if your chuck is open, or if the door is open, or if the air pressure is low, your machine might not cycle start. These conditions are different for each make & model machine, so you may have to check with the machine tool builder (not the CNC builder) to get this info.
Just think of all the safety conditions that might be interlocked to cycle start and see if there is a switch, a pressure switch, etc. that might be in the cycle start circuit. |
