Baltazar, I have a Eumach 2150 P we bought at auction. I need the "Keep Relays". Any help would be greatly appreciated. Paul
Dear Users,
I'm working on Aluminum machining facility and we have problem with our Vertical Milling Center Eumach MC-800P, it's equipped with Fanuc 0-MC numerical controller. Just before Christmas last year we tried to change keyboard panel on this CNC unit and there occurred that gap between panel and buttons beyond it was too tight and DEL button has been pushed for few seconds after machine starts. That erased whole data from machine (parameters, macros, programs etc.) and error popped up (see attachment). We had some parameters on paper sheets wrote by hand and we uploaded them into machine, after that we have received another paper sheets with parameters from Eumach company, we have mixed them up with ours and machine started to work, not entirely, but there was some moves in x,y,z directions. But there was problem still, tool change didn't work. We have found the company in Thailand which claimed that they have all we need for this machine (Eumach 800-P + Fanuc 0-MC) (parameter, diagnostic and program - their words). We have bought it from them and uploaded into machine by hand (we don't know how to transfer it by computer connection. We uploading programs to CNC machines by RS32 port but we don't know how to use it for service things) and it occurred that it didn't work. We have compared parameters and it was totally different from ours (maybe it's not wrong - we don't know which one is btw). From this point we have spent money for nothing useful and machine still doesn't work. Does anyone have ANY idea how fix this problem? We will be very grateful for any suggestions/help/manuals or anything.
Below information about machine:
CNC UNIT: Fanuc 0-M
Model: OMF
MFG NR. 2113296
Eumach MC-800P
Serial nr: 8180
YOM (year of manufacturing): July 1993
If You have any idea or question don't hesitate to write private message.
Thank You all from advance.
Kind regards,
Baltazar
- Need Help!- Eumach tool change macro lost in system reset
- Need Help!- Fanuc 0M, Miyano TSV-25, data lost
- Data sheet lost - 60HS78DE076D
- Need Help!- Fanuc 21i-M lost all data with no backup
- Need Help!- rover 336 data lost
"Keep Relays" are used by the machine builder to select configurations and enable certain features on the machine; it maybe unwise to use them from a different model.
Baltazar, recreating the "Keep Relays" is not a trivial task; it would be advisable to get a knowledgeable service tech in if you can't get the info from an identical machine.
"we're exploring other avenues" exclusively?
