Old 09-12-2006, 11:53 PM
Ashu is on a distinguished road
Question Not Booting sometimes Fanuc 21iT
Machine has Fanuc 21iT system , It is observed that sometimes after power ON Booting sequence doesn"t get complete and it remains hanged. after many power On/Off it works. Now the problem frequency is incresed. It is a turning m/c. Any suggestions pls. This problem was started from one incident of one phase failure. Before that it was perfectly OK.
Old 09-15-2006, 05:03 AM
xavierdemoura is on a distinguished road
Nothing to check !!! Call FANUC to see the problem. Maybe needs replace an board !!!
Daniel
Old 09-15-2006, 11:03 AM
*Registered User*
Bluesman is on a distinguished road
If you look inside and your servo modules have a - in the LED this happend to us. There is a relay (24volt suply) that has to function in order to complete the boot up.(bring up the 240) (Called Fanuc) Now this was a 16c Makino pro3 Fanuc. But it is posible you have the same problem.
I am not real kean on the electrical stuff I am a process guy. But I do get into some of this stuff. Hope it helps
Bluesman
