Old 09-08-2006, 01:38 PM
AZDEN is on a distinguished road
Axis won,t reset on Fanuc O-MC
According to the manual I should be able to reset the relative and absolute positions to zero by going to the appropriate sceen, keying in the selected axis addresses to make them blink and pressing cancel to reset them. When I attempt this, the adresses don't blink. Can anyone help?
Thanks.
Old 09-11-2006, 11:54 AM
la_coterie is on a distinguished road
You can't reset the absolute postion to zero other than by referencing. The relative you can reset by pressing X or Y or Z or all together and pressing cancel after reffing - any help?
Old 09-11-2006, 12:42 PM
Thanks for your reply. That's been tried with no luck. I think I may have bigger troubles, When I go into MDI and attempt to input G90, nothing happens when I press the "G" key. when I then press the "9" key the g appears on the screen. I'm befuddled.
Old 09-11-2006, 12:51 PM
off the top of my head that sounds like somebodys been 'effing with the parameters..
Old 09-11-2006, 12:57 PM
Hang on. The G key is the 9 key (at least on mine)
Old 09-11-2006, 01:17 PM
Al_The_Man's Avatar
You can have two keypads on the 0, called Standard or Full, they are set by P38.3 ****X*** (1-Full 0=Standard).
Old 09-11-2006, 01:26 PM
Doh! yeah!
and I thought it was a trick question
Old 09-14-2006, 02:57 PM
That's it! Thanks All.
Old 07-05-2011, 03:16 AM
prabukumar is on a distinguished road
I need to install/set axis reference for alfa 0c wire edm recently shifted to our shop.
