Dear all.
Does any one worked on Fanuc OA-T controller? I need Z axis peck drill program, but the controller not alowed G83 or G75( even 74).
Thanks for your help.
or use sub program with incremental movement and L repeat
example below will peck 30mm deep from start point Z0.5
Peck is 2.0mm but back-off is 0.5mm so actual peck is 1.5mm
and 1.5 * 20 repeats = 30mm depth
Re: Z axis peck drill program on Fanuc OT controller
Dear fordav11: Thanks so much for your reply.
I fixed it already: Just because one option parameter was not open: The parameter #901.7=0, then all canned cycles is disabled. Evevy thing OK now.
