Old 08-23-2006, 05:01 AM
Hlynur is on a distinguished road
Unhappy Fanuc 21-tb alarms
It is a Harrisson Alpha 550
Year 1996
Serial no .A50085
600 Lathe number A50085/027
We can see alarms
506 +x owertrawel
507 -z owertrawel
507 +z owertrawel
Every time we look at alarm history
at every start
On the display
Even if we clear the history list.
And the lathe will not start.
Hello I get alarm red led number 2 on the cnc moudule
Can anyone tell me the meanig of this.
Old 08-23-2006, 05:38 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Please post the Machine Tool Manufacturer and year so someone can better assist you.
There are a lot of very bright people here that can help.
Welcome to The Zone
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 08-23-2006, 06:10 PM
Al_The_Man's Avatar
pdf.
Old 09-02-2008, 05:35 PM
electromecanik is on a distinguished road
Unhappy Electromecanik - Low control power voltage alarm LV
Hello All, I have a Tsugami FMA3 with Fanuc Control milling machine with a little problem, last time I turned it ON the Y axis servo drive had an ALARM 2 code (Low control power voltage alarm LV). I took the driver out and everything looks just fine but the ALARM doesnt get away. I tried changing the command cable to the X axis but the ALARM remains in the same driver. Does anyone knows if there is a way to fix this problem?
Old 03-24-2009, 08:49 PM
mlbieker is on a distinguished road
I have the same problem on a Mori Seiki Frontier L. Was a solution ever found?
Old 02-22-2010, 12:55 PM
yours_prabhat is on a distinguished road
SRAM LOST
The SRAM data of the machine is gone relaod The parameters than u can get the original screen
Old 02-22-2010, 01:34 PM
underthetire is on a distinguished road
What problem. there are more than one listed here. Frontier L what BTW. A L2 I would assume, witch is a SL25, just newer control. The L1 was a small machine like a AL2
Old 03-31-2010, 12:08 AM
supato is on a distinguished road
FANUC 21-TB ALARM 1020 MOTOR OVERLOAD
THE DRIVE UNIT IS NOT ALARM(--,0)
