This will be one of the 9000 programs probabally, which is enbled by a parameter, this is in the user parameters, rather than the option parameters, unfortunately if the bit is off so you can see the content of them and you do a total programs erase, they go too, so it pays to keep this bit on in normal use.
Do you have the parameters manual.
You will need to get the program first.
LinkBack URL
About LinkBacks
