Old 04-12-2006, 11:16 AM
Enda is on a distinguished road
Hitachi Seiki Seicos
I want to connect my hitachi seiki to my pc using Cimco software,
i need to know the setting and how to go about doiing it on my machine abnd the settings for the cimco server, its just new so my knowlage of it aint great, so easy steps would be appreciated.
the hitachi seicos sigma is basically a fanuc 21 series with a few hitachi parts added.
any help would be appreciated.
Enda
Old 04-12-2006, 12:16 PM
Al_The_Man's Avatar
Here
http://www.cadem.com/ncnet/ncnet_dncdetails-41.htm
Old 04-14-2006, 05:50 AM
Stu_M3 is on a distinguished road
I use cimco software on a fanuc OM1 maybe the settings are the same. Heres a screen shot of my setup.
Stu
Old 04-14-2006, 06:02 AM
stu
Old 12-13-2009, 04:48 PM
mark simmons is on a distinguished road
My Hitachi Seiki VA 50 seicos system will not start up, could this be due to a leaky capacitor not holding charge, causing the system to fail?
Old 12-15-2009, 10:01 AM
alexfanuc is on a distinguished road
What´s on the screen?
Do you see anything on the screen?
Is there any alarm in any of the pcb´s? (behind the display?)
Regards,
Alexfanuc
Old 12-15-2009, 11:14 AM
Regards,
Alexfanuc
Hi Alex, there are no alarms behind the display, but a Circuit Breaker in the cabinet popped due to the solenoids going wild at one point.
We think we have located the problem to the 5V power supply. When the machine has been turned on and warmed up for a while this voltage reads as it should (5V) However if the seicos system is turned off for a period of time and then turned on the voltage reading from the power supply is as small as 4V, but as the cabinet and controls warm up this reading increases. We have an external power supply that we are going to monitor this reading with to establish if this is the cause.
Many thanks for replying, I will keep you posted on the outcome.
Cheers
Mark
